If it makes you feel any better I've done absolutely everything you've done trying to diagnose a dead cylinder on my slicktop... no luck at all. I think it's the injector... ugh.T45 wrote:Ah, another great day! Swapped plugs and nothing changed. Swapped coils and nothing changed. Checked wires and connections between ECU and PTU again and all appear to be fine. Checked wires between PTU and coil again and all appear to be fine. Checked power and ground again and all....you get it.
So after diagnosing everything I bent all of the female connections so that just in case it had a bad connection I could eliminate it. Then when hooking my MAF back up I over tightened the clamp and....yup.
So I figured WTH and left the maf open from the filter. A little dirt won't hurt it. I go to start it and it turns over like 4 times and GRRRAZZZDFGGERESSSAZZZZZZZZZZ.
Apparently my starter is shimmed too far, not enough and broke or the bolts came loose. AAAARRRRRRRRRRGGGGGGGGGGGGGHHHHHHHHHHHHHHHHHHHHHHHHHHH HHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH HHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH HHHHHHHHHHHHHHHH HHHHHHHHHHHHHHHHHHHHHHH
Thanks for that tidbit tech! I'll pull it today and see what's up. (fingers crossed).Q45tech wrote:A very very rare condition on 90-92 VH45 was that the cam lifter arms jumped off [primarily on #2] and the intake valves wouldn't open.............easy to pull passengerside valve cover to make sure.
Great news! Now go have fun with it!T45 wrote:The timing was off by 1 tooth on all cams. After re-assembling it runs like a brand new engine! So excited!
I'm kind of bummed though because I lost that cool loping sound it used to have, sounded like it was cammed. Oh well, cams will solve that once we can source them.
Got the rad in and plumbed up, another day and we'll be burning them down properly. Vids to follow!
Q45tech wrote:We have seen lots of VH45 destroyed from not torquing crank bolt to > 260 lb/ft and oil chain slipping................did you monitor real oil pressure in PSI [no light monitoring allowed] every time you cranked engine and during runs?
Many dealer techs are lazy and get into trouble with chain guides or just replacing front seal. German Gut N Tighten doesn't cut it..always measure.
I losen mine and retighten every 60k.....................now at 18.5 years and 319k.
