Datsun project needs a motor what do I use?
A forum for owners of S30 and S130 Datsun Z's... 240Z, 260Z, 280Z and 280ZX!
Genki_Slider
Car: 280z & Rogue sl awd & Altima 2.5 SL cvt
Ok here it is plain and simple. Some of you have read my posts in the past and know what I planned to do. Well it didnt happen. now I need to get this daty up and running the least expensive route possible.
basically I need a motor for a 280z that wont cost me an arm or leg.
Pharaohabq
Car: 92' Nissan 300ZX NA
Well... Motor on the cheap... do you still have the original motor? What area do you live in?
Mr1der
a small block chevy in all honesty would be the most cost effective.
Genki_Slider
how much does that cost?
Mr1der
there's a lot of factors in that...how much power do you want?
manual or automatic?
who's doing the work?
Genki_Slider
I give up someone take this project from me
SEV6
Car: Tu madre es facile
Genki_Slider wrote:I give up someone take this project from me
Please let me know if you're serious.
ehime
Put a 13BT Rotary in it, I got a guy here in my RX7 club that has one in his. 260hp with meth inject and 7psi. That car makes me cream. If you wanna get rid of it, email me, I got a spare engine in my storage that was ment for your car.
teamloco
Car: 1991 Nissan 240sx
L28et... swap is kinda easy wiring is easy. L28ets are pretty quick.We swapped one in my little brothers 76 280, all in cost less than 3k for motor, trans, driveshaft.
We did get a super sweet deal on an '82 turbo motor with 6k on the clock and a T-5 with the same.
I_Farted
Car: 1990 180sx
Genki_Slider wrote: Ok here it is plain and simple. Some of you have read my posts in the past and know what I planned to do. Well it didnt happen. now I need to get this daty up and running the least expensive route possible.
Sr20det bro...Check out the site...They got a sr swap kit for the 240z but i think the 240z and 280z have the same chassis.....You might want to e-mail them to confirm that
http://mckinneymotorsports.com/products
I_Farted
Car: 1990 180sx
ohhh and check these dudes tooo
http://www.vildinimotorsport.com/
d1skoolbus
Car: 2001 S2000
F20c with Itbs!!
SxMachine
Car: Im on a horse
Well I havent read any of your previous post so i'm not quite sure what u were tryn 2 do and "inexpensive" isn't exactly a budget range but I understand. The least expensive route in my opinion would be something you could find the most parts for without breakin pockets and a KA or any of the nissan v6's would be the best and probably the easiest to mod at any time. Even a max vq30/6spd tran into any rwd is a great option for decent power on a small budget. Mckinney I belive makes mount kits for all those options. I'm all most certain you could get the z to at least CRANK for under 2k by sticking with a usdm spec engine
Return to “Datsun Z Forum”
