mzdafrk wrote:I am very curious about that myself? Has anybody found some good aftermarket suspension for the rear?
Aftermarket suspension for the rear of a 710 consists of performance shocks ( Koni, Suspension Techniques,KYB, Bilstein....etc) and decambered leaf springs.
Decambering the leaf springs means to take away the curvature in them. Spring shops do the job, plenty of spring shops around. All big rigs use leaf springs.
Adding a sway bar will give it Corvette esque cornering capability. For the front, all 510 parts work. The only difference is the sway bar bushing brackets. Coil over suspension from Ground Control works fine. You can also swap in Datsun 280ZX strut assemblies. If on Budget, cutting the front springs will lower the ride. Add good struts like Koni or adjustable KYBs and you are set. Sway bar a must to maximize suspension performance.
ADDCO has sway bars ( I bought a kit for my 710, and recently a kit for my 610.)
Jaime.____________________________________________________
