Rats...
Well I guess ill be researching how hard it might be to fit more rubber under it.
Most images i've seen of LS swaps completely destroy the firewall and tunnel.
I also just thought it be kinda cool sitting there with no belt.
Did not see that coming on the steering either. Does it help with exhaust clearance on that side by chance. I know the steering shaft is always a problem on everything else.
R200's come in 240sx 280z's also believe. (a just "wrx" rear end will not hold up) I guy brought a LS swapped wrx in for .....a new rear end. I popped the hood like
Ill just weld a R200 and run bias ply tires again. The sidewalls flex so you don't get the chip and chatter. It actually worked out great although tire life is insanely bad.
