wildcat08 »
https://forums.nicoclub.com/wildcat08-u136916.html
Fri Jul 24, 2009 3:00 am
I have the same problem. It was really bad last week when it was over 100 degrees everyday. I pulled the vents out yesterday and drove around a bit and it was quiet. However, that could have been because I had just driven it a few hours earlier. Before I put them back in, I applied some silicone lubricant that can be used on plastic and vinyl.
Remember that if you pull the vents out and unplug the airbag light, you will need to reset the light or else the SRS warning light will flash continuously the next time you drive. The procedure is in a sticky.
I had the dealership look at this about 3 weeks after I got the car. They told me that they ordered a part and adjusted for a better fitment, but didn't tell me exactly what part it was. They 'couldn't duplicate' the other rattles in the cabin (speaker grille, door panel, etc.)
I'll let you all know if it is any better when I leave work today.
