Did you check your bulbs? Do that first before replacing anything else.craze K wrote:I finally got my suspension fixed and the exhaust done and its finally inspected..However, Last night I found out that the dashboard lights don't work. Does anyone now where the fuses for that would be located. If the fuse is good, What or where do I go from there. Thanks to all who contribute to this forum, it has helped me out alot...
Forget the gentle crap, start smackin the dimmer switch. It'll come back on.Gerardjg wrote:You should also look at the dial dimmer switch on the dash, take it out and clean the contacts, sometimes gently banging on it helps
I just have too much other stuff to do so I just keep smacking.yodawill2000 wrote:Wurde to the smackage. If that fixes it its time for some re soldering on the back of the dimmer.
Soldering is the way to go. Very easy to do. Did it on the (now ex) gf's 93 j30 last year. As far as I know its holding up great. Wish it wasn't, she's a b*tch. lolyodawill2000 wrote:Wurde to the smackage. If that fixes it its time for some re soldering on the back of the dimmer.
I'll try to explain as best as I can. It was my first time.Victor wrote:What's the procedure for getting the dimmer control out? I have to tap on mine too to make the dash light up.
FunkRider wrote:Soldering is the way to go. Very easy to do. Did it on the (now ex) gf's 93 j30 last year. As far as I know its holding up great. Wish it wasn't, she's a b*tch. lolyodawill2000 wrote:Wurde to the smackage. If that fixes it its time for some re soldering on the back of the dimmer.
