dash wiring help?
idriftnsj
Car: 90s13
anybody know which wire 2 splice into 2 wire an aftermarket tach
Brandon93240
Car: 1993 240sx
You should have a power and a ground, use a 12 volt switched source for the +,a good solid ground, and the signal wire gets its signal from the ground side of the ignition coil. I believe its the green wire at the coil plug, but don't quote me, I haven't worked on an E in a long time.
jlwade
Car: 1990 240sx
Yes, I did it to mine. I think there is a green /black wire out of the coil.
