matt_a »
https://forums.nicoclub.com/matt-a-u69225.html
Thu Dec 20, 2007 5:00 am
I know that the topic of squeaks, creaks, and rattles has been brought up here many times. But last night I FINALLY found the origin of one in our Versa that has been driving me nuts. We have been hearing a consistent rattle coming from the upper portion of the dash, right in the middle. I had assumed it was coming from under that dash panel which is directly above the storage compartment (above the stereo). So last night I removed that piece and drove around. I was still hearing the rattle, but I couldn't tell where in that space it was coming from. I started feeling all around and all of a sudden, I found it! It's not coming from that area at all. It was coming from farther back behind that spot where the dash literally meets the windshield glass. The dash assembly is vibrating against the glass right in the very center. I took a piece of paper and folded it over several times to make it thick enough and then wedged it in that space. IT WORKED!!! The rattle stopped! Now I just need to find some foam or rubber or something which I can wedge in there permanently and won't show. Just thought I'd share in case anyone else has the same rattle.
