SwappedZed »
https://forums.nicoclub.com/swappedzed-u248976.html
Fri Jun 12, 2015 4:05 am
To start, I have a 1994 z32 tt and I'm replacing the head gaskets with the engine in the car. Now before everyone says to just pull the motor, I don't have the space or a lift to pull the motor. If I could, I'd pull it. So back to my issue, I have the upper and lower intake pulled, timing belt, water pump, ext, off the front if the motor, the 8 head bolts, the two 10mm bolts, and the down pipes unbolted, but the heads still will not budge. Do I have to remove the power steering pump too, or what am I missing?
