I have unfortunately, I’ve done about 3-4 drain and fills. Noise never changed. It doesn’t change pitch with speed or rpm. Just a very mono groan. Cold and warm doesn’t affect it either, Car has never thrown a code, did some freeze frames with scanners and live data to check if anything odd could be seen but nothing noticeable to my eyes. I’ve already prepped to pull the transmission. Just wanted to spare me the trouble. I figured once I have it open it’ll reveal the damage done to it. I’ve never heard or seen a reference to the tc sprag clutch before so I may investigate that then see if I can match up some characteristicsVStar650CL wrote: ↑Sun Oct 16, 2022 7:40 amSounds more like the Torque Converter lock is slow to disengage, which is most likely just a sticky solenoid. There are no clutch packs in a CVT except for Forward/Reverse, and your whine could be the TC sprag clutch (that's the same setup as on a regular A/T). So have you tried a fluid change?
So this is the only real video reference I can find that’s the same sound. It’s not my car but it’s the same noise. Mine is maybe about 30% less audible but that could be due to a cracked manifold currently lmaoVStar650CL wrote: ↑Sun Oct 16, 2022 7:40 amSounds more like the Torque Converter lock is slow to disengage, which is most likely just a sticky solenoid. There are no clutch packs in a CVT except for Forward/Reverse, and your whine could be the TC sprag clutch (that's the same setup as on a regular A/T). So have you tried a fluid change?
I can confirm it makes the noise in the air just free spinning in Drive.VStar650CL wrote: ↑Sun Oct 16, 2022 4:35 pmIf it doesn't change pitch with speed or RPM then you have a really weird situation, because it's definitely rotational. Even the TC sprag should change pitch under some circumstances. I'd get the front end in the air with the VDC turned off and see if it will make the noise in drive with a stethoscope on it.
I'll keep this in mind and put the car back in the air on Tuesday and go through with a stethoscope to help pinpoint if its in the bell housing or the casing on the final drive side.VStar650CL wrote: ↑Sun Oct 16, 2022 6:15 pmThe sprag in the TC will make noises like that if it fails, although you'd generally expect it to change at least a bit with RPM. It will also make noise if there's not enough fluid reaching the TC, but I'd expect a bunch of codes if the pump was failing. So if you hear the noise mainly in the bell, it could just be a bad TC and nothing wrong in the tranny itself.
