CVT Transmission Fuid Change DIY Write-Up
dave08902
Car: 2010 Nissan Rogue 360'
Re: CVT Transmission Fuid Change DIY Write-Up
Postby dave08902 » Mon May 04, 2015 6:54 am
yoko911 wrote:How did you get this data? what software/Hardware are you using? i would like to monitor my own Rogue.
dave08902 wrote: I then took car out for a drive to warm it up and it took 8 miles before I got the temp count up to 161.
This screenshot is from Autoenginuity, it is a PC based scanner. It is not very expensive and you can only buy the Nissan enhanced data. To be honest, I gave it to a friend of mine since I brought the Launch and Autel scanners.
If price is a factor, the Autoenginuity is a very good scanner and has about 90% of the Nissan Consult scanner except J2534 programming. I compared the data from the Autoenginuity and the Nissan Consult 3 with my Rogue and has 100 % coverage on the Rogues. I don't know about other Nissan's, that is why I said 90% before.
dave08902
Postby dave08902 » Mon May 04, 2015 7:02 am
joesera wrote:No tranny cooler on my '08. Just an AC condenser in front of the radiator.
The Trans cooler is directly mounted on top of the transmission and is a round container. The CVT fluid travels into the cooler directly through ports and then back into transmission. The coolant travels to and from the radiator to the cooler via hoses. There is no cooler lines that contain CVT fluid and it is all internal to the transmission. The only method is to do a drain and refill several times.
darylzero
Postby darylzero » Mon May 04, 2015 9:07 am
The Trans cooler is directly mounted on top of the transmission and is a round container. The CVT fluid travels into the cooler directly through ports and then back into transmission. The coolant travels to and from the radiator to the cooler via hoses. There is no cooler lines that contain CVT fluid and it is all internal to the transmission. The only method is to do a drain and refill several times.[/quote]
This is the trans cooler. Image from ImStricken via this post. transmission-oil-cooler-for-a-rogue-s-s ... 62969.html
If you turn the car off and disconnect one of those hoses in the picture you will get trans fluid.
Please correct me if I'm wrong, but I just did it and got drops of transmission fluid unless I'm mistaken.
It should be just like this video except we are not cleaning the cooler.
https://www.youtube.com/watch?v=WZ6VSfvNGW8&hd=1
skip to 2:37
joesera
Car: 2008 Rogue SL AWD
Postby joesera » Mon May 04, 2015 10:24 am
dave08902 wrote: The Trans cooler is directly mounted on top of the transmission and is a round container. The CVT fluid travels into the cooler directly through ports and then back into transmission. The coolant travels to and from the radiator to the cooler via hoses. There is no cooler lines that contain CVT fluid and it is all internal to the transmission. The only method is to do a drain and refill several times.
dave08902, your description matches what I see, and could also explain why the dealer offer drain & refill only, and not flush for this vehicle.
darylzero wrote:This is the trans cooler. Image from ImStricken via this post. transmission-oil-cooler-for-a-rogue-s-s ... 62969.html
skip to 2:37
darylzero, mine does not have a trans cooler in front of the radiator, just an A/C condenser, which is bigger than the tranny cooler ImStricken showed and has an A/C lines connecting to the A/C pump.
Thanks for your help fellows.
di_gent
Car: 2008 Nissan Rogue SL FWD
Postby di_gent » Mon Oct 19, 2015 2:57 pm
darylzero wrote:
di_gent wrote:I am going to get the AmsOil Synthetic CVT fluids from a local supplier it's going to be only $12.65/Quart (tax included). i checked their website and they have tested it and it performs just as good as the Nissan NS-2 CVT Fluid. here is the link http://www.amsoil.com/shop/by-product/t ... e=CVTQT-EA
i think some of the experts will discourage against it but i hope it will all go well :D. Any major concerns?
Did you ever do this? Just wondering how it went with AMSoil CVT fluid?
I know it's been a while from when i originally wanted to do this but i finally got it done and used the AmsOil a few weeks ago. I put over 3,000 km on it after doing it. I just came back from a trip to The Canadian Rockies, more specifically Banff and up to the Colombia Ice field. I did notice that the transmission whines a lot when going through the mountains while on cruise control at 120 km/hr. does any one else notice this whining?
The alarming thing that i found out was that i took out 6L ( yes, 6 liters i still have the bottles!!) and 200 ml (6.6 quarts)of transmission fluid!! :wtf2: :wtf2: :wtf2: I am not sure how that was possible and I didn't let it completely drain because i got a bit worried when i saw the oil pan fill up all the way to the rim. there was a thin line flowing when i plugged it back. I thought i might not have enough oil :ohno: :ohno: . I did not jack the car it was on a level concrete floor. I have owned this car since 2012 and had no issues with the transmission and put over 60,000 km on it. The transmission oil was pitch black. Maybe i will upload some photos. I added about the same as the rest of the guys 4 quarts and 23 ounces. can someone tell me how is it possible that i took that much oil out?? :confused: :confused:
darylzero
Postby darylzero » Mon Oct 19, 2015 3:01 pm
^ If you moved the gears i.e. D-R-N while it was draining would do it.
What level is it at now when the car is warmed up?
di_gent
Postby di_gent » Mon Oct 19, 2015 3:17 pm
its on the on the high end but below the hatched area on the dip stick. and i did not change gears while it was draining.
harryg
Car: 2009 Nissan Rogue SL AWD
Postby harryg » Mon Oct 19, 2015 6:37 pm
I get this whining as well, especially on a hot day going through the mountains/hills. Sounds like a supercharger whine of sorts. This happens on my '09 SL AWD Rogue
di_gent
Postby di_gent » Thu Oct 22, 2015 2:40 pm
Here are some photos of the oil i took out, pretty dark. it looks like my dipstick is slight different than Dave's. Yes, the graduated cylinder reads just over 150 ml but i spilled a bit so that's why i said i took out 6L and 200 ml.
engineer20
Car: 2015 Nissan Rogue SV AWD Premium Package
Postby engineer20 » Fri Oct 23, 2015 12:56 pm
is this the same on the new current generation or 2015 nissan rogue? same drain plug, same location/similar, and same hidden dipstick? i didn't see a dipstick that easily came out like the oil one, so it's accessible by screwdriver, i guess after seeing this, i'll look for it. anyways, it's a 19mm drain plug? wow, that's huge. but does this apply to the 2015 as well and how often do you recommend a drain and fill and do you do the 1st more sooner to get rid of wear metaisl from the break in period or no, just at 30k? Thanks. do you drain and fill at 30k or flush it at 30k? the dealer said flush at 30k but will drain and fills every 30k be enough? does this cvt have a filter that's accessible? the 09 taurus i have turns out not to have a filter that is easily accessible, but it's rather inside the transmission, so does the new xtronic cvt or even the cvt on the previous generation have a trans filter or no, is it way inside the trans, or does it not even have one way inside the trans?
engineer20
Postby engineer20 » Fri Mar 11, 2016 11:20 am
Thanks. I know that drain plug, I have a 2015, but it's similar, but in your picture, you see the silver thing next to the trans pan? more toward the center, or towards the passenger side, that silver thing? That also has a drain plug, right or is that the cvt trans, or is that the differential for awd? Because I opened that up as well as the black drain plug and the fluid that came out was the same and was green, so if I want more fluid to come out, do I open up both drain plugs, or not the silver one? Also, can you "drop the pan" or is it worthwhile to do so? DOesn't seem that hard adn you could drop the pan, but you'd replace the gasket, or is it rtv? and is there a trans filter or cvt filter to CHANGE that's accessible after dropping / removing the pan, or no? If not, there's no need to drop the pan, then and just doing drain and fill,s but if you want the car to last a while, you should change the filter, is there a filter, or is it deep inside the trans and not accessible after a pan drop, therefore making a pan drop a waste of time, emergney, and money for the new gasket?
apparently, autozone has a universal tranny cooler, is that true? Can you just get an auto parts store one? I heard it was outside and easy to install, not in the trans (that'd be hard), and you can use aftermarket ones, or no, use the nissan one? thanks.
dave08902
Postby dave08902 » Sat Mar 12, 2016 8:06 am
engineer20 wrote:is this the same on the new current generation or 2015 nissan rogue? same drain plug, same location/similar, and same hidden dipstick? i didn't see a dipstick that easily came out like the oil one, so it's accessible by screwdriver, i guess after seeing this, i'll look for it. anyways, it's a 19mm drain plug? wow, that's huge. but does this apply to the 2015 as well and how often do you recommend a drain and fill and do you do the 1st more sooner to get rid of wear metaisl from the break in period or no, just at 30k? Thanks. do you drain and fill at 30k or flush it at 30k? the dealer said flush at 30k but will drain and fills every 30k be enough? does this cvt have a filter that's accessible? the 09 taurus i have turns out not to have a filter that is easily accessible, but it's rather inside the transmission, so does the new xtronic cvt or even the cvt on the previous generation have a trans filter or no, is it way inside the trans, or does it not even have one way inside the trans?
I looked at the 2014 FSM and the procedure is different. You also need to drain the torque converter and the servicing is different.
Chowcman
Car: 2015 Rogue SV Family Tech PW
Postby Chowcman » Mon Mar 14, 2016 12:57 pm
Stealership quote me $35 a quart of CVT. Is it really that expensive?
I though Nissan is a modest brand for Modest consumer. They think they are Infinti where they can charge an extra premium for parts.
darylzero
Postby darylzero » Mon Mar 14, 2016 7:27 pm
Chowcman wrote:Stealership quote me $35 a quart of CVT. Is it really that expensive?
No. http://www.amazon.com/Nissan-999MP-NS30 ... B00AKYOZDY
Google the part # 999MP-NS300P to find it at other places.
psyman42
Car: 2001 Honda Accord EX (Totaled)
2007 Honda CRV EX (Traded In)
2014 Nissan Rogue SV Premium Package (Sold)
2017 Nissan Rogue SL Platinum Reserve Premium Package
Postby psyman42 » Sat Apr 30, 2016 3:03 am
I have a 2014 Rogue, Do I follow the same steps in this DYI to change myTranny Fluid? Really surprised there hasn't been a separate write up for the Second Gen Rogues in regards to this topic. I'm currently approaching 25K Miles.
richy17
Car: 2009 NISSAN ROGUE S FWD CVT
Postby richy17 » Thu May 05, 2016 7:08 pm
Hi, i owned a 2009 nissan rogue FWD. planning DIY cvt oil change this coming weekend. Do i need to pour all the 5 quarts of oil? Thanks
Agent Black
Car: Nissian Rouge 2012
Postby Agent Black » Fri Oct 14, 2016 4:13 am
@dave08902, Is their anyway you can re-upload the images?
Agent Black
Postby Agent Black » Fri Oct 14, 2016 11:19 am
Actually, NVM... It seems Photobucket was having a problem with their servers and that's why the images weren't loading but now it's fixed!
JamesO
Car: 2011 Nissan Rogue
Postby JamesO » Mon Jan 09, 2017 1:25 pm
Thanks for this tutorial! I felt like a complete moron looking under our '11 Rogue S yesterday because I couldn't find the CVT or oil drain pans for the life of me. All I saw were protective panels. I was about to succumb by having the dealer do this for us rather than saving $100+ by doing it myself. It just dawned on me though -- these pictures are from under the front end of the car! :rotflmao We had been receiving free oil changes through a pre-paid service contract that just ran out, so I had no clue!
JamesO
Postby JamesO » Mon Jan 16, 2017 11:51 am
My fluid change was all be effortless. The whole thing couldn't have been easier. Thanks for this tutorial!
I used Nissan fluid to maintain the warranty. The dealer wanted $250, so I still had considerable savings.
DoitYourselfMike
Car: Nissan Rogue 2012
Postby DoitYourselfMike » Thu Jun 29, 2017 7:49 pm
Thanks For Great Pics changed mine today! Great measurements i put the 4 quarts and 10 ounces! Drain took longest as i wanted all of the old as much out and in with the new! The color was brownish and i put the new Ns-2 CVT fluid.....Note does not look anywhere like new fluid :ohno: . Oh forgot to say i had a 7 quart pan and almost filled to top. Yikes :ohno: almost 2 quarts overfilled thank god i changed. Vehicle has 65000 miles on it.
Hopefully fixes the "Limp Mode" as i also changed the Radiator Coolant as well about 2 weeks ago hopefully all this DIY did the trick if not still saved huge on taking to Dealers.
Last edited by DoitYourselfMike on Thu Jun 29, 2017 8:28 pm, edited 1 time in total.
t.aboud16
Car: nissan rogue 2013
Postby t.aboud16 » Tue Jul 24, 2018 7:21 pm
thank you for the info
mstrmstr
Car: Venom Red ROGUE 08...and 4 others
Re: CVT Transmission Fluid change and testing
Postby mstrmstr » Wed Aug 29, 2018 4:45 pm
I recently changed my fluid- VERY Easy to do. I sent a sample to Blackstone labs and found a higher than normal count for aluminum,iron,chromium nickel and manganese. Viscosity was one point from being to low. Suggest EVERYONE change fluids at least every 60K. The failures come from the steel link belt in the tranny and this needs the best protection you can do..
Tattoo1088
Car: Rogue FWD SV 2011
Postby Tattoo1088 » Tue Feb 04, 2020 7:07 am
Hi, I did check my tranny fluid, on a cold tranny, and not idle. I've always been on the middle mark. Am I too low on oil? Thank's
casperfun
Car: 2009 Nissan Rogue SL AWD - Indigo Blue
Postby casperfun » Tue Feb 04, 2020 12:26 pm
Simple, drive it for 20 minutes in 70-80 degree weather.
Then check.
Tattoo1088
Postby Tattoo1088 » Tue Feb 04, 2020 1:02 pm
Thank's
Do I check it with the motor idle or not?
casperfun
Postby casperfun » Tue Feb 04, 2020 1:50 pm
Idle.
Try to get it in the middle of the cross hatch.
Optimum point.
Return to “Rogue Forum”
