Ever Victorious wrote:Since when has any manufacturer ever chosen the more logical way to do something?
OK, so I'm apparently mistaken on the FWD/RWD difference, but go ask your dealers. The lower end cars and higher end cars DO use a significantly different transmission. This was discussed before a few months ago, back when Scott@WCN was still posting here.
Besides that, most manufacturers DO use significantly different transmissions between the top and bottom models, and it's not just gearing.
Good points. Answers:
1: I didn't say it'd be more logical. I said it'd be simpler and cheaper. Which is what manufacturers always choose if they can. Why would they devote unnecessary resources, especially to an economy car that needs to remain low-cost, if it wasn't necessary?
2: As I said, I don't know any facts regarding the differences between Xtronic variants. That was my guess. My point was that it has nothing to do with the Z.
3: A good point, but it misses the details. For one thing, the trans in the GP and G5 are not the same at all. Nissan uses a lot of the same transmissions between multiple cars, which is the topic at hand here. Yes, they may have internal differences, and a part of that is related to strength and durability. The other obvious reasoning, though, is that each engine has different power and efficiency needs, which necessitates different gear ratios. The point I was trying to make was that when set gearing is not a factor, there is no sensible reason to waste time, resources, or money developing separate variants of the same component when you can stick with one.I wasn't talking about random manufacturers that often do things. I was talking about Nissan specifically and their known methods.
I'm not trying to call you out or show you up or anything (my post wasn't personal, it was about the info). I just don't see slippage after braking and the idea of the Z making more power evidence enough alone that the two would be different. (For instance, regarding the slippage, is it even known if it's unique to the V's CVT? Because if not, it's an irrelevant point in the strength discussion.) The fact that the VQ makes twice the torque the MR does is certainly a viable reason to some extent, though.
If there has been definitive proof that there are indeed different version of the CVT then of course I'm wrong. But all I'd seen in the thread was guessing and speculation (some of it inaccurate) so I offered up some facts and a few guesses of my own.
