It may be "pretty well known", but it's dead wrong. The CVT fluid is only exposed to the temperature of the radiator outlet tank, which is much cooler than thermostat temperature even in hot conditions. The coolant there has already passed the radiator and its temperature is far cooler than the block. The only time outlet tank temperature will get anywhere near "engine operating temperature" is under very severe engine loading or if the system malfunctions causing the engine to overheat. Your statement shows an utter lack of understanding regarding cooling systems.2013SL3.5 wrote: ↑Thu Jul 01, 2021 5:10 amIt’s pretty well known at this point that the stock “through the radiator” CVT loop installation on most North America cars can’t handle the extreme summer temps, and in fact cause the CVT fluid to reach operational temperatures that decreases effective lubrication which in turn contributes to premature CVT failure. So, “if your cooling system is healthy and you're not lead-footing it, you shouldn't have heat issues even in extreme temperatures” isn’t true, unless you’re living in an area where temperatures remain cooler.
Heck, it isn't like people don't drive Altimas at 140F with the A/C blasting in Saudi Arabia. That's damn hot for you and me, but not for a tranny. Making the graph of heat-produced cross the graph of heat-dumped primarily requires load. The ambient matters of course, but much less. Lead-footing across the Sahara dunes, that needs a radiating cooler.
And that 176 was 10 days ago running up the side of a mountain in Tennessee in 95 degree weather. Up till then it was between 145-156. No doubt that temp would have been 176 in 32 degree weather.VStar650CL wrote: ↑Fri Jul 02, 2021 12:25 pmHeck, it isn't like people don't drive Altimas at 140F with the A/C blasting in Saudi Arabia. That's damn hot for you and me, but not for a tranny. Making the graph of heat-produced cross the graph of heat-dumped primarily requires load. The ambient matters of course, but much less. Lead-footing across the Sahara dunes, that needs a radiating cooler.
He's a Nissan Mastertech, I would use less of your mouth and more of your ears if I were you.2013SL3.5 wrote: ↑Thu Jul 01, 2021 1:13 pmLol thanks for wasting everyone’s time. Evidently you are unable to answer even the first simple question, and your obviously over inflated opinion of yourself has lead you to hijack my thread from the beginning to show off your internet expertise, lol.
The above quote, yep I wrote it, but deleted it almost immediately after realizing it’s not worth getting baited by a forum troll “expert” who has no life (seriously, over two thousand posts in less than a year?)
Next time try keeping to the subject, and not pissing off brand new members with needless insults. I know this will probably be tough for you, psychologists commonly call your issues an inferiority complex and your response is sadly predictable.
Wondering if you have diagram of where this t-stat this is? I noticed my 2011 rouge is running a little hot 190-195 on hot days driving in the city. Was lower before, fluids are less few thousand kms.VStar650CL wrote: ↑Wed Aug 25, 2021 4:19 pmI have to revive this thread because I have a Blue Light Special in the Live-and-Learn department. Some of you may have noticed I just installed a CVT temperature gauge on the wife's '13, mainly because I got tired of using my phone for an instrument panel. That CVT has always run 160~170F in hot weather, 140~150F's in the winter. We've had the car for 70K and it gets new fluid every 20~25K, and it's always run at those temps. Not that 170F is harmful, but I kept noticing that D1dad's Altie and a lot of other forum folks generally saw temps 20F or so cooler than that. My customers who watch their temps generally ran a bit cooler too. I wondered why, so along with installing the gauge, I started poking around looking for a reason. Lo and behold, I discovered that the embedded thermostat that's supposed to shut off coolant to the beehive was stuck wide open, not just a bleed-flow when warm like it's supposed to. So it was dumping hot coolant into the beehive all the time, not just when the tranny needed warming. It's probably been that way since we bought the car. I changed it out and presto, 140F on flat highway instead of 160F, 150F in the hills instead of 170F.
That's like -- c'mon, man. That 'stat is something nobody ever thinks about. Lots of techs don't even know it's there.
Now I'm wondering how many cases of "repeated failure" might owe something to that butt-stupid little valve.
I got it in March 2022 used with 22,000 on it. Currently it has about 28,000 miles. I haven't had the fluid changed but didn't know it needed it for a few 1000 more miles. I am not sure what the CVTz50 is but I will look into it.VStar650CL wrote: ↑Tue Aug 09, 2022 7:42 amSlamming down like that isn't normal. It certainly could be from a hot tranny, but not necessarily. Do you have CVTz50 to take the CVT's temperature and read any codes in the engine and CVT? Has it had any fluid changes?
