I30DAD »
https://forums.nicoclub.com/i30dad-u151960.html
Tue Dec 28, 2021 4:17 pm
These CVT transmissions have been around long enough that there should be more than “buy a new one” from mechanics. Seems Nissan holds detailed operational engineering details so close that I’ve yet to find anyone who truly understands what goes on with solenoids, pulleys, and stepper motors.
So, when ANYTHING goes wrong, the answer is “replace the $3000+” CVT.
I’m not believing thats the only answer after having a few of these.
Mine went from strange shifting occasionally to an inability to shift properly shortly after I lost the bottom of the front bumper and undercarriage cover at the beginning of summer. It had P0841 DTC until I changed fluid twice and now has added P0965 P0776 P0746 to the list. Curious.
I’ve developed a few hypotheses as to what might be going on and how a valve body replacement might be the answer. First, I’m looking into how I can inspect the drive belts while it’s on the vehicle before I hang my hopes on a valve body replacement cure.
Hypothesis #1 - The drive belts aren’t ruined. If the drive belts were worn too far, I wouldn’t get acceptable performance when temperatures are low. If the belts were worn, they’d always slip, not only slip when warm/hot.
Furthermore, the behavior is more like being in a “gear too low” than slipping. I get high RPM, with rapid deceleration after easing the throttle and, at times, engine laboring to stall as in being in a gear “too high.” These would be issues with incorrect pulley ratios and not slipping behavior. If the belts were slipping, there’d be insufficient traction to cause deceleration in low or stall the engine in high.
Hypothesis #2 - pulley ratio changes are compromised by heat degraded coils or motors. As fluid ages, it’s ability to cool the electrical components (coils and motors) in the valve body that govern “shifting” is compromised. In a vicious circle, hot fluid degrades more rapidly, resulting in higher temperatures, accelerating the degradation. The coils and motors degrade concurrently as it all runs much too warm.
Temperature degraded coils commonly function adequately until ambient temperature increases, then becoming weaker and fluttering. Anyone who’s replaced a coil to fix a Kenmore gas dryer, or worked on a pinball machine is familiar with these phenomena. So a P0776 or P0746 DTC is consistent with this sort of coil issue. “Ambient” in this case being that surrounding the components.
Hypothesis #3 - body design cools CVT. The ridiculously low clearance of the front bumper and undercarriage cover is required in order to channel air over the portions of the CVT that cool it. I’ve never seen this mentioned, but it seems that CVT issues begin after this happens as its been the case in 3 different Altimas that I know of.
Another common theme in these 3 seems to be delayed motor oil changes. Perhaps the elevated temperature of worn motor oil and it’s proximity to any CVT fluid cooler exacerbates the wear of CVT fluid which itself is already too hot.
Hypothesis #4 - gunk from overheated CVT fluid clogs channels preventing smooth flow. Obviously I don’t know the characteristics of the NS3 fluid over time and at temperatures and Nissan is guarding that as a state secret, but it seems NS3 has 4 purposes:
1) Cooling Components
2) Lubrication between some materials
3)Adhesion between other materials
4)Hydraulics
As it is overheated and ages, it separates into a goo and a thin liquid. Much like cholesterol in blood. When draining and refilling, the thin “blood” is replaced while only some if the goo/cholesterol remains and clogs channels.
This would explain the slowly improving behavior of my CVT after two fluid changes as well as the sudden new codes. It’s a cooler winter, so the goo remains and is working its way through the entire system hopefully settling in the pan.
Hypothesis #5 - another fluid change after allowing the fluid temperature to get very high may lower the viscosity of the goo and more will drain.
I would expect performance to be even better after that change as the channels would be clear and properly behaving fluid does it’s jobs.
A few points:
1) Yes It’s wishful thinking but it’s not entirely hope. There seems to be ample evidence this CVT could be rescued.
2) Behavior is steadily, if slowly, improving after two fluid changes
3) These are hypotheses, not facts, based on much observation, so please don’t blast me for arriving at erroneous conclusions.
4) Please DO explain, if you would, why my hypotheses are incorrect. That is one point of my post
5) Citing your experience along with a blanket statement that “it’s ruined” or “wrong”, isn’t helpful unless you explain what I’m wrong about. The other point of my post is to try and decipher what’s actually going on inside these CVT. It’s astonishing that there is so little understanding of how these devices actually work.
6) A link to a detailed treatment explaining their operation including what a coil, stepper motor and/or fluid does during operation would be most helpful as I’ve yet to find such information
