CVT: D v. L
A forum for the Nissan Quest... minivan lovers unite!
RonBranam12
Car: 2016 Nissan Quest SV
Just curious as to when Low should be used in stead of Drive with this transmission. I know Drive is the normal operating mode. I have been in the habit of using low range on other cars when on a down grade to use the engine for compression braking. Is that OK with the CVT? Also, if climbing a grade would Low be appropriate? Both of these at slow speed of course. Less than 25 MPH.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Yes, it's fine to use Low range on a CVT just as you would on a conventional A/T. The only difference is that the CVT is being locked into the lower range by software and not a mechanical gearset.
RonBranam12
Thanks. I wish there was a "Like" button. At Laguna Seca Raceway there some short 6% grades when Low comes in real handy.
phmichel
Car: 2013 Nissan Rogue S AWD
2017 Nissan Quest SV
VStar650CL wrote:
Thu Oct 14, 2021 4:31 pm
VStar - I've noticed something: On my 2013 Rogue AWD if I hit the L button at like 40 mph, the OD goes off and revs go real high (like putting a MT in 2nd gear from 4th). But on our 2017 Quest if I do the same thing it seems to recognize the current road speed and compensates somehow by adjusting the RPM and matching it to road speed (it doesn't over-rev). I assume its part of an improved design or CVT firmware on the newer Jatco?
VStar650CL
Technical Expert
phmichel wrote:
Sat Oct 16, 2021 10:31 am
The gen1 Rogue TCM software was among the first ever used by Nissan, and some aspects of it were pretty primitive by later standards. It isn't exactly Jatco, either -- Hitachi makes the TCM hardware and also writes the firmware to a spec produced jointly by Nissan and Jatco. So when there's a fly in the soup, it's usually impossible to determine which of the 3 chefs let it land there. ;)
RonBranam12
A little off subject but...
Now that I've been driving around town, I've noticed a noise. When first accelerating (usually after backing up, but not always) and when decelerating into what I believe to be the last downshift, I hear what sounds like a belt slipping. Not a high-pitched squeal like fan belt, more like a burp. Both of these are sometimes, not all times. Any thoughts?
phmichel
VStar650CL wrote:
Sun Oct 17, 2021 5:46 am
Ha! :chuckle: Well said. It's not really a "fly in the soup", just an observation.
VStar650CL
Technical Expert
RonBranam12 wrote:
Sun Oct 17, 2021 7:44 pm
That could be judder. If it is, the TCM will have detected it and you'll have a P17F1 or P17F0 stored. It could also be a loud or balky stepper motor in the CVT, a balky TC sprag-clutch, or something that isn't the CVT at all like a leaky active motor mount. Get it scanned with a trans-capable scanner and see what's in there.
RonBranam12
VStar650CL wrote:
Sun Oct 17, 2021 8:09 pm
I don't like the sound of that. Pun intended. I think it's time I took this info. to my mechanic. I hope he won't mind it came from the internet. BTW: Will the ELM 327 I received in the mail today show this?
VStar650CL
Technical Expert
If you're hooked up with CVTz50 it will read both TCM (transmission) and ECM (engine) codes, so judder codes will definitely show up. It won't do other systems. If your mystery noise is from something like an ABS solenoid, you'll need a better package like Torque Pro that can do work support for all the systems in the car.
RonBranam12
I did a bing search and none of the sites showing Nissan OBDII codes listed those two. Granted, none of these sites were official Nissan. Is there an official Nissan OBDII code list?
Hey, I'm trying to get into this technology. I admit, I'm a dinosaur. I just this uear got a smartphone.
VStar650CL
Technical Expert
Nissan has always kept the judder codes sort of QT, they're "proprietary" and not OBD-II (although they are OBD-II compliant). They don't even turn on the MIL, and our instructions about them are to take no action about either one unless the customer complains about palpable transmission misbehavior. To explain what they mean, P1F71 indicates minor belt-slip (judder) was detected. The belt is probably okay but the Valve Body may need replacement. P1F70 is the "death code." It means the TCM detected major slippage, so belt damage is almost certain.
Return to “Quest Forum”
