3Q Jay »
https://forums.nicoclub.com/3q-jay-u16163.html
Sat Jul 02, 2022 2:04 pm
David-
I recall 6 grooves in the pulley? 0-25 deg? so 15 would be the 4th hash. remember to be hot idle at about 650 rpm max in park, AC off.
Is your light a "dial back" light? if so, then what does the gun say when you have the 0 deg (yellow paint?) indexed?
Regardless, you are using the +12v wire, which feeds all the coils, which also means that your light is triggering not just from #6 (the desired one for setting timing), but from 2, 4 and 8 as well. probably no big deal, just something to keep in mind. More importantly, using the 12v wire is less definitive than using a stub of HT lead between the coil pak and plug #6. Yeah, it's a pain in the butt to do it the preferred way.
Practically speaking, my tests have shown anywhere from a 1 to a 4 deg offset between the two methods. It really all depends on how your light triggers. bear in mind that when you use the 12v feed to the coils, that line changes voltage (drops) when the ECU tells the coil to start charging the primary (think points dwell on your old alfa). the voltage on that 12v line will go back up at the instant the ECU opens the trigger pin on the coil to fire the HT (secondary) lead. So, is your light triggering on the rising voltage signal (likely) or the falling voltage? you might try flipping over the inductive pickup to see if that makes any difference?
