Rickjames8 »
https://forums.nicoclub.com/rickjames8-u259239.html
Sun Feb 07, 2016 12:20 pm
So I am doing pretty well at my 60k service, until I encountered a stripped hole in the tensioner pulley body. That little tab where I'm supposed to put one of the 10mm fan bolts and release pressure. I turned it super slowly as advised, and it's still stripped. I can twist the bolt in and out, so there are *some* threads, but not enough to hold the bolt as I put pressure on the piston.
I plan to replace this part anyway. Is it ok to cut off the belt with a knife or snips, or would that cause too fast of a release for the cams? Is there any other way to slowly release the tension?
I've tried getting in there with a tap, and it's in too awkward of a place.
