C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Sun Oct 12, 2003 8:06 pm
The problem is the injector drivers may not be able to handle too large an injector. Too short an injector pulse signal may not yield the correct injector pulse. It can be somewhat similar to the problem with getting too close to 100% duty cycle. The largest injectors JWT runs currently are 72 lb injectors. Not sure if this is a limitation due to the injector driver.
Secondly, at too low a MAF signal, the ECU may not be able to compensate and/or may adversely affect the ignition timing too much. Low MAF signals tend to tell the ECU to advance timing since the ECU will think there is a lighter load. Depends on th type of ECU. This has been discussed quite a bit in the E-Manage mailing list. Noone could confirm in my scan of emails on that list if Nissan ECU's do this or not. But I usually only look for particular types of posts there or I just delete them. I know Orion has backed off his timing about 3 degrees while using his hacked MAF. I have my E-Manage timing backed off at higher MAF readings. I still get some light ping occasionally on hot days, but I think it might be because my MAF is maxed under full load. I'll see what happens once I upgrade to a Z32 MAF.
