jlimback »
https://forums.nicoclub.com/jlimback-u158118.html
Fri Apr 09, 2010 5:01 am
I recently got a 2007 Nissan Sentra 2.0 for my wife. We've had it a bit over a month and have not had any problems, aside from a creaking/clunking noise coming from the passenger front suspension.
I took a look, and sure enough, I found that the strut spring was shifting about 1/2 an inch at a specific point in turning the wheel to the left...causing the noise. I checked the bolts in the engine bay...all tight.
On top of this, last night driving home, the car started to bog on acceleration. I also noticed that the indicator on the dash panel gauge wasn't showing the normal P, N, D, or L...it had disappeared. I turned the car off and back on during one of these episodes and the indicator re-appeared and the car drove normally....until I used the brakes. Every time I pressed the brake pedal, the indicator disappeared, until finally it stayed off.
So, any input here would be appreciate....not much knowledge in these things. I did search the boards for similar problems but didn't come across anything...if I missed something, please just direct me there.
Thanks in advance.
