I got my head back on the block with new head gasket put it all on the way i took it off. And it wont start.
pisses me cause i looked and check every thing at least 2 times....And as far as the cams and getting them lined up i done what this foum said and what the book showed in the pics........... See i car jumped time the crank was off by 3 links and the cams was off by 2 or 3..I set the motor to TDC by hand when i had the head off the block......
And check it after the head and cams was all in place and finshed....Iam completely puzzled iam that sure that its right
i checked ever plug and wire all fireing hot..all wires hooked up right
Ok cams both key ways pointing up i put cam chains on lined it up with crank first the E cam was next lined it up perfect .then adjusted the intake cam so that the silver link was on the dot ended up at 11:00 and the key way was at 9:00.. i dont see what the hell i did wrong but i must have done something..
i can here compression from the motor out of the muffler now at least!! In the 6 years ive owned the car ive never heard it befor
And on the distrbotor i put the niddle or bug to the #1plug wire is that correct..Cause i didnt see where it showed the #1 pistion notch all i seen was the #one plug wire where it plugs in the distrubtor thats what i lined it up with.....i have the 91 ka24de And as a note i know hat you all tell me is just help and iam greatful Thank you
