themadscientist »
https://forums.nicoclub.com/themadscientist-u2806.html
Sat Aug 20, 2005 4:45 pm
No proble, here's the trick.put a transmission bolt into the appropriate hole in the block by the head.Take a socket and put it's open end down over the teeth of the flywheel's starter ring and rotate the engine so the closed end wedges against the bolt.this will lock the crank in place as you turn the pully bolt. Use a breaker bar with a long pipe on it so you will not have to bounch or perform any jerky motions to loosen it, just steady pressure. You can use the same procedure to tighten the bolt again, just flip sides.
