CoWay HID foglight conversion - 2k2 Maxima
audtatious
Here is the end result of the installation. I will document the installation process soon.
CoWay H3 HID kit - 6000k
I am running 6000k HID headlight bulbs and HID H3's (both sets from our sponsor). This is a great conversion and Roger (CoWay) was available via phone on a Saturday to answer any question I had. Great support!
nismo1219
Car: '12 Nissan Altima 3.5SR
'99 Nissan Maxima GLE
looks great matt! just out of curiousity, did they come with any type of braket to mount the ballasts? i have been talking w/jeremiah about his setup and he said that his kit came with a braket he used to mount them, which would be handy to keep them from sliding around...just in case you had to do some "aggressive" driving, lol!
audtatious
Yes, they come with brackets. I have them mounted behind the fogs. Each side has a 10mm bolt location. On the drivers side, there is nothing there and on the pass side it is the lower mount for the washer reservoir. I used the supplied 10mm bolt for one side and the factory bolt on the other. I put 2-sided tape on them as well to ensure they don't flop around.
nismo1219
good call, how much did they run you?? also, jeremiah said i have been changing my foglight bulbs the hard way? i have been crawling UNDER the car, removing the splash guards and wheel-well trim to get in behind these SOBs! they are a MAJOR PITA!! is there an easier way???
audtatious
Per Roger, you can pull the headlights and have access from the top. My headlight bolts are rusted in (I ripped a top off trying) so I had to go from the bottom.
I think he has the H3 HID kit for around $179
jltibbs
Car: 2015 Nissan Versa SL
1994 Infiniti Q45
2000 Infiniti I30
looks awesome matt.
do the co way kits come with fuses and relays? or is it extremely plug and play?
audtatious
On mine it was quasi-plug-n-play. I cut the wires and re-fed them through the fog housing for a "factory" fit. Then I simply soldered the factory plug back on and it connected right up. If it were not for the weird Nissan fogs I would not have had to do anything but change the plugs.
nismo1219
no good man. as there is little room under there as it is, im trying to find a kit as close to plug-n-play as possible. i get in a real bad mood when im cramped up under there, holding the wheel-well trim back w/my head, flashlight with my teeth, and pliers to undo/redo the friggin' door hinge thingy!! PIT-freakin-A!!
audtatious
It _is_ a "plug-n-play". I just took it to the next level.
I'm not sure about the 4th-gen fogs, but my 2k2's have a sealed-screw backing. In order to keep that in place, I cut and resoldered.
jltibbs
1994 Infiniti Q45
2000 Infiniti I30
i so ghetto rigged mine. that's the same way my 3000k kit is, ben, i just rigged it in there by cutting the hole and covering with tape
nismo1219
i prefer the "stock" type assembly. i have a soldering iron so i guess if its not too much trouble, seeing as how i've never soldered anything before, i will try to cut the wires, feed them through the sealed backing and solder them back together and wrap w/electrical tape when i do mine.
jeremiah, we have GOT to find a better way to get my fogs out than the way ive been using. lets try to take out the screw on the side and see if they slide out like yours?
jltibbs
1994 Infiniti Q45
2000 Infiniti I30
i got you bro. we gonna hook it up
Those look killer.
Now Matt can see where he's going.
audtatious
Just barely. Old = bad eyesight
nismo1219
i thought things got better w/time...like say, wine...or women!! LOL
jltibbs
1994 Infiniti Q45
2000 Infiniti I30
audtatious wrote:Just barely. Old = bad eyesight
umm actually matt, studies show that bad eyesight come from too much 'alone time' with yourself.
nismo1219
LMAO! yeah, i hear if it gets in your eye...you'll go BLIND!!
