coupe gauges in a hatch?
S1d3way
Car: 1991 240sx
I was wondering if anyone knows if the Gauge cluster out of a coupe s13 will work in my 91 hatch. I really like the center tach on the coupe gauges, but idk it the digital speedo stuff changes anything. (ex. plugs or if it needs a different signal or what.) I don't want the hud just the gauge cluster.
s13sickboi
Car: 1997 Nissan Hardbody XE
Should be same thing.
Always keep in mind that the only difference between hatch and coupe is the back.
S1d3way
Car: 1991 240sx
ok thanks, just figured i should ask
ceniack
Car: 1992 240sx Coupe
1993 JDM Nissan Caravan
2011 Subaru WRX STI Hatchback
2012 Subaru Impreza Hatchback
make sure the donor car is a 91 or later or the tach won't work (you can swap out the tach in the cluster i believe)
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
ceniack wrote:make sure the donor car is a 91 or later or the tach won't work (you can swap out the tach in the cluster i believe)
Not true. Sohc tach will work....it just needs power spliced into the signal wire.
ceniack
sorry, it won't be plug and play...
