corroded sparkplugs already!
ESPER
wsup, i just checked my NGK's today and they are corroded all around, is this normal?? considering i have only had them for 4 months or so?? How should a spark plug look according to naturla wear and tear?? thanks!!
red240ne
Car: mmm...donuts
If they're looking bad, then it may be something that is wrong with your fuel system or it's misfiring or something. Check this site out to find out what your plugs look like. That oughta get you started.
topless@vabeach
Car: Electronics, anything that has trons in it.
Which part of the plug are you talking about the top or bottom. If you are talking about the top where the boot is connected then try putting a little electro jelly on it to keep it from getting nasty.
ESPER
well the top or the tip i understand will have a bit of wear, but the middle is what i noticed to be corroded white!!
thanks for the link!!
nnkfws333
Car: 2004 Infiniti G35 and a 1989 Nissan 240SX
check your timing with a timing light
ESPER
how much are timing lights?? and is that all i need, just use the timing light (is it that easy??) thansk again!!
Queamore
Car: Cars.
Also check the gap it may be to small and burning to hot. Timing could also be it a timeing ligh at auto zone goes from 30 to 80 bucks I got one at 60 I thinkIts pretty good and very useful. and yeah it's that easy.
ESPER
ok will do, thansk guys!! (but yeah i have a pretty excessive pinging problem too ) but yeah i got an tuo muchanics class and we are going to learn a lot of basic stuff, but htey got timing lights etc. and i am just gonna use theiers in lieke a week or two hehe
