So, I was digging around about bores for the CA and came along these two articles about max cylinder bore for the CA. Now, as we all know, max bore isn't very far for the CA, maybe 84.5 if you got a good block. What has interested me more is the topic of core shift. For those that don't know, it's basically when the molding of the cylinder bores and block get messed up during manufacturing process and the mold is moved (a careless worker, vibrations, etc). One of our down-under brothers was saying that this is a common occurrence with early CA blocks.
This pertains to max bore because if you have core shift, one of your cylinders will have a thinner wall than the other cylinders, not allowing further boring. Has anyone else seen evidence of core shift on their CA? Also, it got me thinking, that maybe the CA is best suited to be a sleeved block. I haven't seen anyone use sleeves on any engine build, as it's mostly an American thing to do on V8s or domestic cars, but it would be a really good option for the CA, since boring it to a large degree is impossible.
I suggest reading through these topics from our Aussie brothers.
http://sxoc.com/vbb/showthread.php?5062 ... ultrasonic
http://sxoc.com/vbb/showthread.php?3895 ... =84mm+bore
