But then again considering the need to balance heat transfer ability in hot [mixed] climates with aged components [bent fins/external corrosion on radiator, etc air bypass leaks] ............. do long life coolant mixtures make sense when you can just add/subtract on a bi-annual basis.
Drain 4 quarts, add distilled water in early Summer, drain 4 quarts add 100% new coolant [AF] every year in late Fall.
Measuring the conductivity of coolant solution [with a VOM]......how much voltage is generated from aluminum rad cap flange to a probe stuck into center of opening [in the solution] tells you everything you need to know about additive package [protection ability].
http://www.findarticles.com/p/.../pg_2
