suobs »
https://forums.nicoclub.com/suobs-u207997.html
Tue Oct 23, 2012 7:05 pm
My 1994 4x4 King Cab D-21 pickup, manual transmission, 4 cyl engine seems to be losing coolant. I've topped the reservoir twice to just above the minimum level (with engine cold) twice in the last 3 weeks. According to a shop manual I have (Chilton), the colorant in the coolant (Prestone - greenish yellow) should make it easy to spot a leak, but I'm not seeing anything greenish or even wet-looking anywhere after running the truck, at least in the places I've thought to look (around hose ends, radiator drain, under the radiator, surface of the skid plate, and the ground under the truck after driving).
Any ideas or should I just assume I didn't get it filled right the first time? I'm planning on flushing it soon.
