BaliLover wrote:I noticed that alot of the projector replacement instuctions want you to put the low beam on the inside instead of the outside like it normally is. Is there any reason for this? I figured it would be better to have it on the outside edge so you get a wider beam pattern but I could be wrong.
Hmm, I'm not sure what instructions you're referring to. I agree that the low beams should optimally be placed on the outside of the cluster. Perhaps due to the depth of the Hella low beam housing as compared to that of the high beam housing, it might be easier to mount it inboard? All the pics of the conversion I'd like to do show the low beams on the outside and I think it's the most aesthetically pleasing way to do things.
Can you tell me more about the instructions you're talking about, BaliLover? A link perhaps?
-kouki
