haleakalag »
https://forums.nicoclub.com/haleakalag-u205250.html
Tue Sep 27, 2016 12:29 am
Hi. New issue today. The 09 g37 convertible trunk partition latch on the right seems to have lost tension compared to the driver's side. The partition/separator on that side will not stay locked/click into place when I raise it up, before lowering the convertible top. It sits just above the latch. The right side is fine. I took the piece apart and the spring seems ok and the latch opens and closes, just not enough tension I guess to hold that side in. I tried to twist more tension into the spring, and even put some rubber bands inside the mechanism, but still won't click and stay down. The outside trim piece is labelled 84948jj50a, but I can't see a number for the latch/spring mechanism which easily screws onto that piece. Any ideas for a quick spring repair, or better yet, the full replacement part with the latch and spring. THANKS MUCH.
