Continue Charging Phone When Car is Off
StayThirstyMyFriends
Car: 2014 Rogue SV
When I am charging a device on the USB port or the lighter connection, and then the car is turned off, power is cut so that the device is no longer charging. Can they be rewired so that they don't lose power, and will continue to charge devices while power is off? And can I do it myself?
First Post! :wavey:
SlimBisquit
Car: 2014 Nissan Rogue SL in Mystic Jade
I use an usb adapter in the lighter plug under the arm rest
Car: 2014 Rogue SV
Thanks. Didn't realize that one stays on.
Jostudly
Car: 2009 Nissan Rogue
Anyone know how to re-wire for a 09 Rogue that only has the one 12 volt?
ImStricken06
Car: 2008 Nissan Rogue (sold)
2013 Hyundai Santa Fe
2016 Kia Sorento
you guys would need to drag in a line from the battery into the cabin in order to have constant positive/power.
SlimBisquit
I'm sorry, i'm wrong, the front and center power outlets do not work the car is off. I believe the cargo area does though, if thats right? then thats stupid
Return to “Rogue Forum”
