PapaSmurf2k3 »
https://forums.nicoclub.com/papasmurf2k3-u3044.html
Wed Apr 14, 2021 1:48 pm
You should call Megasquirt with the model you have and all associated hardware. They should be able to point you in the right direction, or tell you what to datalog during a cranking event.
Pro tip though, you should pull that fuel pump fuse until you figure out the no spark issue. It'll prevent you from having way too much fuel in your cylinders/contaminating your oil.
