Toahk wrote:Also be sure all spark plugs are out, fuel pump fuse is pulled and pressure is out of the tank, and you start the car up untill it dies after pulling fuse/letting out pressure in tank. As stated be sure you hold it Wide Open Throttle and crank it 5-7 times, and be consistent of the cranks on every cylinder.
