S14tat »
https://forums.nicoclub.com/s14tat-u875.html
Thu Oct 23, 2003 3:51 pm
also another cuase of failure is when the car runs lean. alot of people tend to just do a turbo without doin a proper fuel system. like me. lolz i was running without a fuel pump at first, at 7 psi. very unsafe. then i got the pump and raised to 8 psi. which is borer line limit, then i fixed my crank shaft position sensor and then the boost jumped to 9 psi on its own, and that was no good, so i needed 370cc injectors. after i put those in, i was running soo rich on boost that i destroyed my cat. so i had it dyno tuned and now it runs beautiful.
