CODE 440 GAS CAP, non OEM
Emile
Car: 2000 I30t
hi everyone
MY CAR 2004 I35 62,000 miles
coded 440 at autozone replaced gas cap with generic non OEM
and after 5 or so miles service light went off
now it's back on [500-1,000 miles later]
tried putting cap on several times but light is staying on this time
1/ Could it be I really need an Infiniti gas cap
2 /PS since I replaced cap with non Infiniti part would this void my premium warrentee purchsed from dealer?
thanks for any suggestion you all may have
Emile
maxhopper
Car: 02 Maxima SE 6spd
Is it storing the same code as before?
I have seen where cheap non OEM caps can cause a faulty seal, but you may have some other evap leak that the system is detecting. You need to have a smoke test done on the evap system to determine where the leak is.
No, an aftermaket gas cap will not void your warranty (only on the gas cap if it was covered under your warranty).
Emile
Car: 2000 I30t
thanks!
since my question, I tightened the cap and gave it a push and side to side motion
service light shut off after about 20 miles
so probably is just a "weak" cap seal
will pick up one from the dealer
-Emile
NutriaforBreakfast
Car: Nissan Maxima 1995 VQDE engine
I think the cap should start "chattering" (when turning it) when it is on tight enough
You might want to go back to autozone to make sure no code is still there even though
the light is off (to ensure a smooth car inspection later)
Emile
Car: 2000 I30t
yep did that"chatter'
had to give it that extra push and "nudge" to get it to work
maybe just a bad cap
figure the one from dealer would be better[maybe]
well at least I am certain it will be more than $11.99
LOL
thanks
