RedZEcks »
https://forums.nicoclub.com/redzecks-u247917.html
Thu Jun 04, 2015 7:04 am
So I've had it with this code. I've searched the internet and everywhere else and no one can give me a definite answer. While most sites say that a code 35 doesn't cause any performance issues, this is the only code showing up at all times. The problem with the car itself is that it will run fine after I clear codes but as soon as I drive it for about a mile and the engine starts heating up there is a fair amount of hesitation and after stopping (at stop sign, traffic signal) and coming to an idle, the engine tries to slowly die by dropping in rpms and eventually will if I don't stay on the accelerator. EGR system has been deleted and I'm not 100% sure what the pinout is for a EGR temperature sensor so I can't trace the wires and fix with the resistor trick I see using on detonation sensors.
Please guys, I need help because the car is basically garage-ridden until this can be fixed.
Thanks.
