redincali »
https://forums.nicoclub.com/redincali-u102928.html
Thu Mar 18, 2010 12:15 pm
and a month later.... heh finally got time to put it back together a couple days ago. she started right up but im still getting a det. sensor code. is that normal? its the only one coming up after replacing my injectors. I actually had 3 that were way off on the ohms.
the car is still idling high, at about 1400rpms. eatin gas like crazy too. tomorrow ill check the timing, or this weekend. while i had it off, i decided to paint the plenum and valve covers. didn't want to over do it tho. but a few scratches did get created while putting everything back together. thanks for the help again, this forum is the best.
just in case u wanted to see
before...
after...
yes, i know. the last owner straight man handled the intake pipes and got crazy with a bright red and blue spray paint on the engine. the shroud is the next to be painted. along with intake new pipes and red couplers. dont want to 'rice' this car out, just want the engine to look better than it did. as for the outside, i want all stock except for my hood, nose panel, and hatch. which will be in carbon fiber.
