Ramius83 »
https://forums.nicoclub.com/ramius83-u6643.html
Tue Apr 10, 2007 6:35 pm
If the posted above information is all good, then it sounds like your detent mechanisms inside the transmission are bad or missing. Worn out detent mechanisms will cause a transmission to constantly pop out of gear.
Upon performing the clutch job, did you happen to remove any bolts on the transmission and a spring and ball-bearing came out of the hole? If so and you did not put them back in, then that is bad. Those are the detent mechanisms.....
