1dollar240 »
https://forums.nicoclub.com/1dollar240-u221.html
Sat Feb 15, 2003 8:23 pm
turning the screw counter clockwise should bring the pedal closer to the floor. clockwise would raise the pedal. This is all based on what i remember, it could be opposite, but you will be able to tell once you are under there. also- another way to limit pedal travel is to adjust the positions of the starter interlock switch and the cruise control cut off switch if your car is equipped with cruise.
