I'm coming to the CA family for this one. Just feel out of place in the regular community..haha
Since I just installed my Spec Stage 2+ clutch and don't want to ruin it with bad clutch adjustment, I've been reading through the FSM and the NICO pages and am just kind of confused I guess. The FSM states to adjust the clutch pedal high to just around 7" off the floor of the car. Mine is at about 5.5" or so. The FSM states to adjust pedal high with the pedal stopper and to adjust free play by adjust the clutch master cylinder rod. I can remove the clutch pedal stopper and still have pedal high around 5.5". I guess before I go turning things and messing with the adjustment I'm just looking for some advice. The Clutch fully disengages and engages fine but the pedal travel is quite short it seems. I've never adjust any of the components since driving the car and I drove on the stock clutch for years and it always drove fine.
Should I just leave the pedal alone and enjoy or should I set the pedal height and free play to OE specifications?
If I adjust the clutch master cylinder rod, does will that raise the clutch pedal high or will it just move the piston inside the master cylinder and just cause me to lose pedal travel?
Thanks in advance guys.
Zak
