countcristo »
https://forums.nicoclub.com/countcristo-u135625.html
Sat Jun 06, 2009 9:32 am
Hi everyone,
I'm a first time user of this forum, so I apologize if I did not go about forum procedure (I did read that sticky for new users and all those links dated 7 years ago are dead). I have a 1997 nissan sentra XE.
Here's my problem. Yesterday, my clutch cable had snapped (while driving, how embarrassing). I couldn't shift gears into first or second or reverse. A person had pulled over asking me if I needed help and he had been able to shift it into first with the engine turned off. He drove it back to my house (about 3 miles) and tried adjusting the clutch cable, but I needed a new one.
Fast forward to today, I replaced the clutch cable with the help of a friend. Since it was both our first time, I'm not sure if we broke the cable because we tightened the adjusting nut (while pushing the withdrawal lever toward the back of the car) to its fullest then untightened it 2-3 turns. We prestretched the cable (pumped it 50 times) and readjusted the nut once more. When this happened, the tension in the clutch disappeared and there was almost no resistance.
However, we don't really think it's the clutch cable, since we just replaced it and don't think it can snap that easily. What's more strange is that I can't shift the gear into first, but when I try (doesn't lock into place) the car moves forward and there's this whirring sound that we believe is the the throwout bearing. With the car turned off, you can switch it into first gear, but can't start it. On top of all of this, one of the times when we tried to start it in neutral, it would not start unless you gave it gas.
Is it the clutch, the transmission, or the engine?
Thank you if you read this lengthy problem and any advice on what might be the problem.
Thanks,Jim
