duece00duece »
https://forums.nicoclub.com/duece00duece-u19525.html
Fri Nov 14, 2008 5:40 pm
Your master cylinder has 2 pistons inside. The primary piston is the one closest to the firewall and the secondary seal is whats causing a leak. If it is leaking into the passenger compartment that means it had to go through the brake booster to get there. You will need to somehow get the fluid out of there or replace your booster aswell. Learned that s*#t at Wyotech.
