unlearning »
https://forums.nicoclub.com/unlearning-u77087.html
Sun Jul 27, 2008 1:08 pm
So last night driving home the car crapped out on me, here is a small detail to what happened.
As driving down the freeway my clutch pedal magically stuck to the floor on its own, with no pressure pushing it back out. As I came off the freeway, I pulled the clutch pedal back towards me and when I tried to push the clutch in again the feel was very sticky and gritty, as if I couldn't make a smooth motion at all.
You could tell something was sticking as when I tired to drop the clutch it killed once because the clutch did not engage after the gas was pressed (engaged late), as well as lunged forward since the clutch dropped once unexpectedly after trying to re-compensate for prior problem by using slightly more gas.
After trying to shift to second going down the road, again the clutch pedal had no "back pressure" and just stuck to the firewall and hung-out there. After repeatedly trying to pull the pedal back and re-disengage and engage the clutch, nothing happened and the car is in a perpetual state of neutral.
So first instinct says it's a throwout bearing or something is wrong within the master/slave cylinders or the lines. None of the lines look damaged at all so I'm still dumb struck. Anyone have an idea about what is actually causing the problem?
Modified by unlearning at 6:26 PM 7/27/2008
