evildky »
https://forums.nicoclub.com/evildky-u13100.html
Thu Apr 22, 2010 8:48 am
you got a z33 trans that was in a z33 and want to know if the clutch from it will work with the z32 trans?...... I'm gonna go out on a limb here and guess that the cluthc splining is the same since all 70-96 Z car's are the same as well as pretty much all other nissan clutches in that period, but I'd also bet the the flywheel is gonna be different, so if you intend to get rid fo the z33 trans thats been adapted to a z32 whoever you sell it to would most likely need the custome flywheel, adapter plate, driveshaft, etc
and are you really sure thsi is in fact a z33 trans taht was in fact modified to fit the vg? I'd say stay away fomr it unless you can see the whole car or at the very least the whole drivetrain taht it was connected to
and your R200 is plenty stroun to hold all the power that you can throw at it, these things are pretty much buullitproof
