Why not try the parts department at you local Infiniti dealerSVTCOBRA wrote:This is the compartment at the top of the center console. The outer door cover shell on mine came off - broke off.
I need to remove the entire compartment and see if I can glue it back or replace the door.
I've looked thru the FSM (not exactly clear as to how to remove), but wondered if anybody here has removed this before.
