doomedfob »
https://forums.nicoclub.com/doomedfob-u180214.html
Fri Mar 04, 2011 6:03 pm
Hey guys. So today I tried to swap my analog cluster with a digital cluster. I had some trouble with the digital cluster so I took it out. While taking it out I guess the back touched something metal and the lights on my cluster shut off. I tried plugging in my analog and it did the same also. I got no tach, speedometer, and all the lights on the right. The signals work (left/right emergency lights) and when I turn on my headlights the backlight turns on for the clusters. The clock still works as well. I honestly don't know whats going on. Anyone care to help? Its a 90 s13
I checked my fuses (type As) and I swapped whatever fuse was blown. My taillights started working XD but I still haven't gotten the gauges to work. I was reading some posts and one said to replace my TCU box, but the chime from the TCU box works when I keep my door open and put my key in the ignition. What else could be the problem? I'm needing some help this weekend cause I'm starting to drive next week
