clocking SR T25
RagingPanda
Car: 78' 280Z
I'm having issues with clocking the turbo. WHat did you guys use? One of the bolt is so cramp in there that i can't even fit a rachet in. I think my friend stripped the other bolt....
Banisher
Snap ring pliers
c-rad
Car: 1991 Nissan 240SX w/CA18DET
RagingPanda wrote:I'm having issues with clocking the turbo. WHat did you guys use? One of the bolt is so cramp in there that i can't even fit a rachet in. I think my friend stripped the other bolt....
You shouldn't be 'un-bolting' anything.
^^^^^^^^ snap-ring pliers. Squeeze the snap-ring together, rotate housing, release pliers.
sdtouge
Car: 1990 240sx coupe
ya it looks like the bolts are it, but its not, i belive iirc it was on teh compressor side, its a big *** ring, like on your shifter lever, youll need some man power, it will help here to have a friend, and have him have a screw driver to pry under the ring when you get it a little. also, practice on your old turo taking it aprt and back together to make sure you can do it.
i had snap ring pliers, and a huge monkey wrech so i could aplly morem fornce on the handles
RagingPanda
Car: 78' 280Z
ahhhhh...I'm such an idiot. Thanks a lot guys.
float_6969
Yes, you ARE an idiot! But THAT is what we are here to help you fix. LOL, I'm JK. Honest mistake, anbody could have made. I won't say that I've done the same thing, but I know this guy....
sdtouge
i made it lol started unbolting them and i was liek wtf?
