Clock Bulbs..Help!
qx4dude
Car: QX4
Hey guys,
I seems like one of the bulbs to lite up my clock in my qx4 has gone out. Its only half lit. Which bulbs do i need and how to do i change them?
I did a search but still no clue!
Empty V
Car: 2001 Infiniti QX4
1982 Chevy Corvette C3 Shark
qx4dude wrote:Hey guys,
I'm pretty sure this is what you're looking for. T 1.5 LED Twist Lock The Dealer charges about $28/ea. Replace both of them with LEDs for much cheaper. If you want the same look buy the white.
Billy
qx4dude
Car: QX4
Hey Billy, those bulbs on that link you posted, will i need one or 2?
Empty V
qx4dude wrote:Hey Billy, those bulbs on that link you posted, will i need one or 2?
What year is your Q? I've got an 01 and it takes 2. All you have to do is pry out the clock/vent panel from the edges with a panel popper(some people grab the vents and pull out with pliers and a rag/towel to protect form damage), disconnect the power/illumination connector and use some really thin needle nose pliers and twist them out. The LED replacements have to go in a certain way so if they don't light up spin them 180*. If you've got a pre '01 I'm sure someone else can confirm the bulb quantity.
Billy
qx4dude
Car: QX4
Thanks Billy,
Your right the dealer wanted 23bucks a bulb.
My Qx4 is a 2002 so it should be the same as yours im guessing? The only problem is that website wont let me order to canada without spending 25 bucks. Who needs 25 bucks worth of Led bulbs? lol
I am having trouble find any other website that carries that led.
Empty V
qx4dude wrote:Thanks Billy,
You could always order 3175 LED lights for your dome lights. You could also replace your map lights, reverse lights, license plate lights, 3rd brake light(takes 9x 168's), climate control lights, vanity mirror lights, interior and exterior turning signals, primary brake lights... the list goes on and on.
Billy
