DCaff300ZX »
https://forums.nicoclub.com/dcaff300zx-u136230.html
Sat Jul 23, 2016 11:12 am
Good news on the "fix", but as you suggest it may return.
One of the things to keep in mind is the complexity of these cars combined with their age, when they sit for extended periods things start to "fade" if you will, even when garaged- mine will often not show time on the clock for a day or two, the clutch canister loses vacuum, and the dome/dash lights will sometimes be dim for a little while until I drive around a bit. All corrosion related stuff I'm sure, the car does always have a way of reminding the owner of it's weakness...
