Check Out My Custom Tubular Manifold
piwiz08
I made this for a friend this week. I decided to share it with you guys. We did a test fit and the wastegate cleared the mount yesterday. After he broke apart 2 eBay manifolds we decided to go a different route.
rico05
Car: 1992 RMS13 w/ CA18DET
Not too shabby!
themadscientist
pretty nice. What metal is it made of?
cmoody2006
Car: 1993 Nissan 240sx vert
Sweet now make me one! lol
adrianfromthecastle
Car: 1992 Nissan 240sx
awesome welding!
piwiz08
i might consider making more but i dont know just yet. the metal is schedule 10 304L Stainless Steel
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
SUS 304 is the heezy fo reezy.
DALAZ_68
Car: 90' 240sx CA18det
ill probly sound like the biggest tard, but
whatis the center tube for, i see where the tubro mounts but that one opening, ill assume BOV mount?
adrianfromthecastle
DALAZ_68 wrote:ill probly sound like the biggest tard, but
external wastegate.
BOV goes on the IC piping....
ca18detgabby
Car: 92 Nissan S13 ca18det SOLD
03 Infiniti G35
thats hot. wanna make me one?
that a T3 flange?
what kind of V-band WG is he using?
piwiz08
thats
ca18detgabby wrote:thats hot. wanna make me one?
that a T3 flange?
thats a tial 44mm wastegate flange
themadscientist
304 cracks easy, add some supports.
r34 gtr
themadscientist wrote:304 cracks easy
So does my voice.
piwiz08
themadscientist wrote:304 cracks easy, add some supports.
yes 304 can crack but this is Pipe that is 3.5mm thick not tubing like the cheap ebay manifolds or what a exhaust header would be made of.
DALAZ_68
adrians_s13 wrote:external wastegate.
i figured it out after i typed it...whats the diff between internal and external...
id take one wihtout an external pipe
Reno
Car: 89 S13, boosted.. RAWR..
how much would it cost to make that manifold but cyl 2,3 on the left side and cyl 1,4 on the right?
basically making it a twinscroll mani
The_Chosen_One
Car: 2009 Subaru Impreza 2.5i
Internal wastegates are usually built into the turbine housing of the turbo.
External wastegate is attached to the exhaust manifold.
DALAZ_68
i understood that part of it...but im wondering performance wise
ive also heard about people welding shut there internal and making it ext...how does someone go by doing that, and is it safe
Anu
Car: Nissan 200SX s13
I think the biggest advantage of this is that the wastegate causes les turbulence in the exhaust, thus resulting in better flow through the exhaust and easier spooling of the turbo, correct me if im wrong though.
piwiz08
im not sure if a twin scroll is possible with the space limitations. ill take some measurements and let you know
piwiz08
Anu wrote:I think the biggest advantage of this is that the wastegate causes les turbulence in the exhaust, thus resulting in better flow through the exhaust and easier spooling of the turbo, correct me if im wrong though.
it does allow forless turbulence but the main issue is the smaller internal gates can only regulate so much pressure at a certain point for better boost control you will need a larger valve to allow for better control of the exhaust gases
Reno
piwiz08 wrote:im not sure if a twin scroll is possible with the space limitations. ill take some measurements and let you know
...cough....cough....copy ...cough....full Race ..chough................................full Race
