Supernick37 »
https://forums.nicoclub.com/supernick37-u53790.html
Thu Jun 07, 2007 5:55 pm
the car 90 q45
the back story
i need to change the oil so i popped the drain plug on the pan, and took the air box off to get at the filter, filled the car with 10-40 max life and 3/4 of a bottle of hyperlube, put everything back together, went to start the car and it took FOREVER to start, so i held the key down 8-10 seconds and it finally started.
the check engine light stayed on, i took it around the block and these are the problems
=takes forever to start=wont rev past 3k (rev limits it self) in N, D, P=when the throttle remains constant the RPMs drop and kick back on making the car buck
and
=the car wants to die when starting out
I ordered in a new MAF and put it in thinking that would fix it but it didnt, so i returned it
the only other thing i can think of is when i was putting in the oil i spilled some over the valve cover and might have fouled out a coil pack... but i didnt think that it would act like this with a dead cylinder... becides it runs pretty smoothly ticks a little but smooth otherwise
anybody?
